Hello. I have a Shelly 2.5.
I want to use one of the switches in detached mode for automations (single click, double click).
However, I have latching switches instead of momentary ones.
Also, the switch I want to use is a 2-way switch.
The problem I am having is that shelly.click is tracking the latching switch state, meaning that if one of the two way switches gets pushed once, then the Shelly registers it as a long press. The next single press of either of the two physical switches does nothing (as expected, the shelly thinks that the long press is over since the voltage drops to 0). Also, double clicking the switch in this state does not register as a single press only.
This is weird, but what I am looking for is a “detached edge” switch mode, which changes the state on every hit instead of reading the voltage.
Is there such an option or workaround anywhere?
