I have a problem with the Shelly integration After a recent updates of home assistant (version: 2023.2.5_18.0.42 running as an app in a container in TrueNAS Scale)
I’ve encountered a strange situation: I have an automation that is triggered by an up/down button connected to a Shelly-i3 and activates a scene to raise/lower blinds.
I don’t see the automations in the automations window in the settings. The two automations are disabled with the log message (for button1 and button2):
failed to setup triggers and has been disabled: Invalid (type,subtype): ('single', 'button1/2')
It seems that events from the Shelly-i3 are detected in home-assistant as events from a Shelly-dimmer (according to the log), which naturally does not support the up/down events, thus the automations are disabled.
Oddly enough I can still control the Shelly dimmer from home assistant.
Is there a way to force home assistant to redetect the correct ip addresses of the Shelly devices erasing wrong connections between entities and devices?
