My living room lights are controlled by the right hand switch of a double gang in the kitchen, and a single switch in the living room itself.
Currently, I simply automate on/off via a switchbot on the kitchen switch.
I would like to install a Shelly dimmer 2 instead at the living room switch (not the kitchen switch as at some point, I will be installing another shelly dimmer 2 for the left hand kitchen light switch- no room for 2 Shelly switches).
The light fitting space could be a possibility too but not going to look at that unless the light switch option is too complicated.
The switch fittings are straight forward on/off switches. I am in the UK so there is no neutral wire.
The images of current wiring are below:
Kitchen switch (right hand side):
Living room switch:
Not experienced at electrical systems but have wired standard switches, lights and plug sockets in the past so would be confident with some advice. All help accepted.
Advice on required connectors would also be helpful.
