Shelly Dimmer 2 shutdown after high temperature event
Hi HA community,
I have two Shelly dimmers in the living room, each of which supplies 11 LED panels. Each LED light has 9 watts, so 90 watts per dimmer. One dimmer is installed in the flush-mounted box and the other under a drywall ceiling. Both have enough space.
My problem is that the dimmers get too hot and shut off after about 5 minutes when the light is set above 20%.
The temperature then rises above 100 degrees and the dimmer switches off.
I tested various Shelly firmwares, turned on Eco mode, recalibrated and tried all possible settings.
How can I lower the temperature?
Alternatively, I would buy other dimmers if I can’t find a solution.
Do you have a recommendation? I would also have no problem using another manufacturer if necessary.
Greetings
Thomas
Ask shelly?
I already ask Shelly, but they have no idea.
I flashed them with esphome and have a load of around 100W (max) LED connected, in a junction wallbox, no heat issues…
Hello and a happy new year
Thank you for your answer @sender86 .
I have try it with ESPhome, but same issue again.
Temp goes up to 104 degrees at 60 watts.
Any ideas ?
Greets
Thomas
What esphome config do you use
this one:
esphome:
platform: ESP8266
board: esp01_1m
comment: Shelly Dimmer 2
substitutions:
device_name: “Dimmer”
max_power: “220.0” # watt
max_temp: “90.0” # °C
Enable logging
logger:
baud_rate: 0
uart:
tx_pin: 1
rx_pin: 3
baud_rate: 115200
Enable Home Assistant API
api:
encryption:
key: “a3IY4ZCA6mLUlID7PUvv1yaoPKJlanbQBv+g9ITLguk=”
ota:
password: “e53efa8445a06bdee39e98537984ab52”
wifi:
ssid: !secret wifi_ssid
manual_ip:
# Set this to the IP of the ESP
static_ip: 172.16.1.103
# Set this to the IP address of the router. Often ends with .1
gateway: 172.16.1.1
# The subnet of the network. 255.255.255.0 works for most home networks.
subnet: 255.255.255.0
dns1: 172.16.1.1
Enable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: “Wohnzimmer-Dimmer-Rechts”
password: “4bnuwqeEkUHE”
captive_portal:
Enable Web Server
web_server:
port: 80
time:
  • platform: homeassistant
NTC Temperature
  • platform: ntc
    sensor: temp_resistance_reading
    name: ${device_name} temperature
    unit_of_measurement: “°C”
    accuracy_decimals: 1
    icon: “mdi:thermometer”
    calibration:
    b_constant: 3350
    reference_resistance: 10kOhm
    reference_temperature: 298.15K
    on_value_range:
    • above: ${max_temp}
      then:
      • logger.log: “Switch turned off because temperature exceeded ${max_temp}°C”
      • homeassistant.service:
        service: persistent_notification.create
        title: Message from ${device_name}
        data_template:
        message: Switch turned off because temperature exceeded ${max_temp}°C
  • platform: resistance
    sensor: temp_analog_reading
    configuration: DOWNSTREAM
    resistor: 32kOhm
  • platform: adc
    pin: A0
  • platform: total_daily_energy
    power_id: power_dimmer
    filters:
    Multiplication factor from W to kW is 0.001
    • multiply: 0.001
      unit_of_measurement: kWh
switch:
  • platform: restart
    name: “${device_name} Herstart”
light:
  • platform: shelly_dimmer
    icon: mdi:globe-light-outline
    power:
    voltage:
    current:
    min_brightness: 460
    max_brightness: 1000
    firmware:
    version: “51.6”
    update: true
binary_sensor:
  • platform: gpio
    pin:
    number: GPIO14
    mode: INPUT
    internal: true
    filters:
    • delayed_on_off: 50ms
      on_multi_click:
    single click
    • timing:
      • ON for at most 1s
      • OFF for at least 0.5s
        then:
        • logger.log: “Single-Clicked”
        • light.toggle: dimmer
    double click
    • timing:
      • ON for at most 0.5s
      • OFF for at most 0.5s
      • OFF for at least 0.2s
        then:
        • logger.log: “Double-Clicked”
        • light.turn_on:
          brightness: 100%
    triple click
    • timing:
        then:
        • logger.log: “Triple-Clicked”
        • light.turn_on:
          brightness: 25%
    Press and Hold button
    • timing:
      • OFF for at least 0.1s
      • ON for at least 1s
        then:
        • logger.log: “Press and Hold - Dim DOWN”
        • while:
          condition:
          - binary_sensor.is_on: switchID_1
          then:
          - light.dim_relative:
          relative_brightness: -1%
          transition_length: 0.01s
          - delay: 0.01s
    Hold button
    • timing:
        then:
        • logger.log: “Hold - Dim UP”
        • while:
          condition:
          then:
          relative_brightness: +1%
          - delay: 0.01s
I cant see anything wrong. Although the formatting is not correct.
For what it may help, this is mine:
wifi:
  ssid: $ssid
  password: $password
  #use_address: 192.168.1.1
  ap:
    ssid: "${esp_name} FBHS"
    password: !secret Fallback_Hotspot
captive_portal:
# Enable logging
logger:
    baud_rate: 0
esphome:
  platform: ESP8266
  board: esp01_1m
substitutions:
  device_name: "shelly-2-dimmer-01"
  max_power: "220.0" # watt
  max_temp: "70.0" # °C
  esp_name: shelly-2-dimmer-01
  ssid: ssid
  password: !secret ssid_wifi_key
uart:
    tx_pin: 1
    rx_pin: 3
    baud_rate: 115200
# Enable Home Assistant API
api:
ota:
# Enable Web Server
web_server:
  port: 80
time:
  - platform: homeassistant
  # NTC Temperature
  - platform: ntc
    unit_of_measurement: "°C"
    icon: "mdi:thermometer"
    calibration:
      b_constant: 3350
    on_value:
      then:
        - if:
            condition:
              - sensor.in_range:
                  above: ${max_temp}
              - light.is_on: dimmer
            then:
              - light.turn_off:
              - logger.log: "Switch turned off because temperature exceeded ${max_temp}°C"
              - homeassistant.service:
                  data_template:
    on_value_range:
      - above: ${max_temp}
        then:
          - logger.log: "Temperature exceeded ${max_temp}°C"
              data_template:
                message: Temperature exceeded ${max_temp}°C
  - platform: resistance
    resistor: 32kOhm
  - platform: adc
    pin: A0
  - platform: total_daily_energy
    filters:
      # Multiplication factor from W to kW is 0.001
      - multiply: 0.001
light:
  - platform: shelly_dimmer
    power:
    voltage:
    current:
      device_class: "current"
    min_brightness: 350
    firmware:
      version: "51.6"
      update: true
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO12
      mode: INPUT
    internal: true
    filters:
      - delayed_on_off: 50ms
    on_multi_click:
      # single click
      - timing:
        - ON for at most 1s
        - OFF for at least 0.5s
        then:
          - logger.log: "Single-Clicked"
          - light.turn_off: dimmer
      # Hold button
      - timing:
        - ON for at least 1s
        then:
          - logger.log: "Hold - Dim DOWN"
          - while:
                condition:
                then:
                      relative_brightness: -0.5%
                  - delay: 0.01s
  - platform: gpio
    pin:
      number: GPIO14
      mode: INPUT
    internal: true
    filters:
    on_multi_click:
      # single click
      - timing:
        - ON for at most 1s
        then:
          - light.turn_on:
              brightness: 15%
      # Hold button
      - timing:
        then:
          - logger.log: "Hold - Dim UP"
          - while:
                condition:
                  - binary_sensor.is_on: switchID_2
                then:
                      relative_brightness: +0.5%
                  - delay: 0.01s
text_sensor:
  - platform: wifi_info
    ip_address:
      name: "${esp_name} IP Address"
    ssid:
      name: "${esp_name} Connected SSID"
    bssid:
      name: "${esp_name} Connected BSSID"
    mac_address:
      name: "${esp_name} Mac Wifi Address"
switch:
  - platform: restart
