Shelly dimmer 2 smooth local dimming
I have a Shelly Dimmer 2 that I installed Tasmota on, unfortunately I was a little too eager and didn’t bother to evaluate the stock firmware prior to flashing it with Tasmota. It works nicely from the web interface but local control with a switch is mandatory in this application too. I have a momentary ON-OFF-ON toggle and what I want is a short tap up to turn the light on, tap down to turn it off, long hold up or down to smoothly increase/decrease the brightness. I have the on/off working just fine but the dimming changes in abrupt steps. Does anyone know if it’s possible to get it to dim/brighten smoothly across the range with Tamota? Am I correct in thinking that the stock firmware can do this?
