Hi
I’m not sure if this is possible…
But I’d like to use a Shelly Dimmer 2 with a retractive switch that goes up and down, where up is on, down is off, hold up brighter, hold down dimmer.
Is that even possible?
If it is possible. What would be the wiring conf on a normal uk light circuit replacement, where neutral is present, look like?
Then in Shelly set up what would the button type and any other settings need to be?
Thanks!!
Dave
