Hi, I am trying to install a shelly dimmer2 in a light switch…
Firstly is it possible to if I only have one switch…
Secondly could someone guide me with what to do… (see attached picture for reference)…
Thank you very much!
16227551672093249757506492921620|375x500
This post is better off in the Hardware section.
But yes you can use a Shelly Dimmer with only one momentary switch. I doubt it is useful with a normal switch.
To connect it behind your switch, you’d need not only the switched phase (L), but also a neutral wire (N).
From your picture it is hard to tell, if a neutral wire goes through your switch box.
