Shelly Dimmer2 entities disabled by integration
I just added my first Shelly device (Dimmer2). It got discovered by Home Assistant and adding it created a whole heap of entities but most of them are disabled.
I have setup the Dimmer2 based on the integration page (Shelly - Home Assistant).
Any idea where I go wrong here?
I have the same situation and I don’t know what to do.
You can use an integration from HACS, then you’ll have all the entities enabled/working.
See here: Home Assistant How To - integrate Shelly IoT devices - YouTube
