Shelly Door Window 2 - State changes
Hi all,
Just bought a couple of Shelly Door Window 2 sensors. I configured both of them via Shelly integration (official). They work good with Open and Close events (they change their state from off to on and viceversa).
The strange thing comes when the device performs some “automatic” action like waking up for “temperature” monitoring, “periodical” or something called “sensor” under the Event Log page of the Shelly app:
As you can see in the Shelly Event Log, there are different “events” regarding “SENSOR GARAJE” related with “temperature” and “sensor” in the INFO field. These events are not related with the Open or Close actions of the door but they arrive to my Home Assistant as state changes (from “off” to “on” and viceversa) that only have 1 second or 2 seconds of duration (as far as I checked it). This is the binary sensor which manages the state:
So, I tried to align magnet with sensor, check batteries and so on. I think it is realated with the Shelly HA integration.
Do you have some experience handling this device?, I do not know how t avoid this kind of behaviour.
Thanks a lot!
P.S: I have configured CoIoT in the shelly battery devices as recommended in addition to static ip. Not related but I wanted to specify it.
No idea?
Just to know how to go ahead…
Solved with pre-release firmware http://repo.shelly.cloud/firmware/dimo/SHDW-2.zip
