Shelly EM Gen3 [Solved]
I’ve flashed a Shelly EM Gen3 with ESPHome and added BTHome as per user @badrpc. That works great.
I’ve also created switches for the dry contact relay and the status LED as per the pinout described here. However, you will see that the IRQ pin is not known.
Everything is working great except the ADE7953, which is what is needed in order to get energy readings from the device (the most important part!). I have tried every pin as the IRQ to no avail. I have also tried changing the I2C bus to GPIO18/19 and assigning the IRQ to GPIO6 and then 7, to no avail.
I tried assigning SPI to GPIO18/19/20 and then using pins 4/5, and then 6/7, to try the SPI version of ADE7953 as described in the ESPHome docs. Both attempts gave me readings for the first time, but they were just maxed out static numbers (like 191,000 volts or something like that) so that didn’t work either.
Does anyone have any ideas as to how I can get this energy meter to work with ESPHome? Here’s my config.
esphome:
  friendly_name: Shelly EM Gen3
esp32:
  board: esp32-c3-devkitm-1
  framework:
    type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  - platform: esphome
    password: "not_important"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Shelly-Em-Gen3 Fallback Hotspot"
captive_portal:
#GPIO 0 is Built-In Relay
#GPIO 1 is Built-In Button
#GPIO 2 does not work as IRQ
#GPIO 3 is ADC for NTC temperature
#GPIO 4 does not work as IRQ
#GPIO 5 does not work as IRQ
#GPIO 6 is I2C SDA; does not work as IRQ
#GPIO 7 is I2C SCL; does not work as IRQ
#GPIO 8 is a strapping pin; does not work as IRQ
#GPIO 9 is Status LED
#GPIO 10 does not work as IRQ
#GPIO 11 does not work as IRQ
#GPIO 12 is reserved for SPI (SPIHD) when I tried flashing
#GPIO 13 is reserved for SPI (SPIWP) when I tried flashing
#GPIO 14 is reserved for SPI (SPICS0) when I tried flashing
#GPIO 15 is reserved for SPI (CLK) when I tried flashing
#GPIO 16 is reserved for SPI (SPID) when I tried flashing
#GPIO 17 is reserved for SPI (SPIQ) when I tried flashing
#GPIO 18 does not work as IRQ
#GPIO 19 does not work as IRQ
#GPIO 20 does not work as IRQ
#GPIO 21 does not work as IRQ
external_components:
  - source:
      type: git
      url: https://github.com/badrpc/esphome
      ref: v0
    components: [ bthome ]
esp32_ble_tracker:
bthome:
  - id: blu_door_window
    mac_address: XX:XX:XX:XX:XX:XX # MAC-address of BLU sensor
    encryption_key: "not_important" # 128-bit key
i2c:
  sda: GPIO6
  scl: GPIO7
binary_sensor:
  - platform: bthome
    window:
      name: "Test blu window"
  - platform: status
    name: "Shelly EM Gen3 Status"
  - platform: bthome
    angle:
      name: "Test blu angle"
    battery_level:
      name: "Test blu battery level"
      entity_category: "diagnostic"
    illuminance:
      name: "Test blu illuminance"
  - platform: ade7953_i2c
    irq_pin: GPIO1
    voltage:
    frequency:
      name: ADE7953 Frequency
    current_a:
      name: ADE7953 Current A
    current_b:
      name: ADE7953 Current B
    power_factor_a:
      name: "ADE7953 Power Factor A"
    power_factor_b:
      name: "ADE7953 Power Factor B"
    apparent_power_a:
      name: "ADE7953 Apparent Power A"
    apparent_power_b:
      name: "ADE7953 Apparent Power B"
    active_power_a:
      name: ADE7953 Active Power A
    active_power_b:
      name: ADE7953 Active Power B
    reactive_power_a:
      name: "ADE7953 Reactive Power A"
    reactive_power_b:
      name: "ADE7953 Reactive Power B"
  # NTC Temperature
  - platform: ntc
    sensor: temp_resistance_reading
    name: "Shelly Temperature"
    calibration:
      b_constant: 3350
      reference_resistance: 10kOhm
      reference_temperature: 298.15K
  - platform: resistance
    sensor: temp_analog_reading
    configuration: DOWNSTREAM
    resistor: 32kOhm
  - platform: adc
    pin: GPIO3
switch:
  - platform: gpio
    pin:
      number: 0
      inverted: false
  - platform: gpio
    pin:
      number: 9
      inverted: true
    restore_mode: ALWAYS_ON
time:
  - platform: sntp
    timezone: America/Los_Angeles
    servers:
     - 0.pool.ntp.org
     - 1.pool.ntp.org
     - 2.pool.ntp.org
button:
  - platform: restart
    icon: mdi:power-cycle
I took a look at the pinout and realized I had SCL and SDA swapped. I think it might be working with this I2C. Edit: It is working.
i2c:
  sda: GPIO7
  scl: GPIO6
@toreupfeet - do you have a link for the guide you used to flash ESPhome on the Shelly EM Gen3?
You’ll need a USB-to-UART adapter, such as an FT232RL. Then you’ll need some wires that you can terminate with 1.27mm headers for insertion into the Shelly. Or, instead of the 1.27mm headers, you can delicately insert bare copper wire if your wire is sturdy enough to allow for it. It worked for me.
On one of he sides of the Shelly, you’ll see the little holes for the 1.27mm headers. You don’t have to disassemble the device in any way. Just insert the headers/wires through the plastic case of the Shelly. Look at the ESPHome docs to see which wire goes where. Remember that TX from the FT232RL will plug into RX of the Shelly, and RX will plug into TX of the Shelly.
Make sure your ESPHome yaml includes ota updates so you only have to flash it over serial for the initial setup.
