Hi
Just installed a Shelly EM on my Solar PV system on the grid side of the inverter
now Shelly spec says the current transformer has a 1% accuracy spec, not sure about the EM.
My inverter is saying 2.515KW , EM shows 2.05 KW.
I dont thing the inverter claimed level is too far out as it agrees with the metered amount generated.
So a mathmatical frig needed in the configuration.yaml
- platform: mqtt
state_topic: "shellies/shellyem-109664/emeter/0/power"
# value_template: "{{ value|float / 60000 }}" # Fix for Watt-minutes
qos: 1
unit_of_measurement: "kW"
you can see where I’ve copied the config from
the ratio of reported values is 1:1.2268
would the correction with a value template be ?
value_template: "{{ value|float * 1.2268 }}"
The only problem with that is it displays on the guage 2.30643852 KW
Three decimal places is adequate, what do I need to add so it just reads "2.306 KW
TIA
