I have just set up a Shelly Door/window sensor using the Shelly for Hass integration. I only see the open/close binary sensor, but none of the others (battery, tilt, lux etc.). Should they show or are they not supported?
Taking a closer look, I can see all of the attributes in the binary sensor details:
Is there any way that I can expose these attributes as sensors?
Use a template sensor.
Thanks.
I am probably just being stupid, but canβt work out how to access the data from the individual sensors.
In template editor:
{% set battery = states('binary_sensor.shelly_shdw_2_e8db84d52025_door_window.battery') | float %}
The battery level is {{ battery }}.
Always returns zero?
Never mind - figured it!
{% set battery = state_attr('binary_sensor.shelly_shdw_2_e8db84d52025_door_window', 'battery') %}
The battery is {{ battery }}.
More something like:
sensors:
shelly_battery:
friendly_name: "Shelly Battery"
unit_of_measurement: '%'
value_template: "{{ state_attr('binary_sensor.shelly_shdw_2_e8db84d52025_door_window', 'battery') }}"
Exactly - thanks!
For completeness sakes (if anyone else finds it useful), the sensor returns the battery level in text format with the β%β already appended. This makes it difficult to use the battery level in an automation. To fix this, and display correctly as a battery level device:
front_door_battery:
friendly_name: "Front Door Sensor Battery"
device_class: 'battery'
value_template: "{{ state_attr('binary_sensor.shelly_shdw_2_e8db84d52025_door_window', 'battery').split(' ')[0] }}"
Same principal can be used for the other sensors - e.g. lux, tilt, vibration.
