Shelly for HASS stopped working after upgrade to 2022.3 - problem with paho-mqtt
The Shelly integration can no longer be loaded as it is missing a requirement (paho-mqtt) - that in turn can not be updated due to a conflict:
Unable to install package paho-mqtt==1.5.1:
  ERROR: Cannot install paho-mqtt==1.5.1 because these package versions have conflicting dependencies.
  ERROR: ResolutionImpossible: for help visit https://pip.pypa.io/en/latest/topics/dependency-resolution/#dealing-with-dependency-conflicts
The recommendation seems pretty useless as I cannot call python or pip from the terminal within HA …
Restarting does not work anymore either as it complains about an invalid configuration.
Somewhat at a loss, hoping for helpful advice …
Benno
Presumably you have a custom component that’s causing that?
Sure enough …
As I have no idea which that might be - and the error message is rather vague in that respect - I’d hope for some suggestion to pinpoint the issue to have at least a starting point for trying to fix it …
So… one (or more) of those list paho-mqtt in their manifest/requirements.
Home Assistant also has a requirement for it:
# homeassistant.components.mqtt
# homeassistant.components.shiftr
paho-mqtt==1.6.1
Those custom components need to update their requirements to avoid causing issues with HA.
Following this issue.
Meanwhile see this ticket: https://github.com/StyraHem/ShellyForHASS/issues/655
Thanks for checking!
So I’ll just wait for the Shelly update, I guess …
Might want to change the topic to indicate that this is about ShellyForHASS and not the built-in Shelly integration…
+1 - Having same problem - super disappointing
I have the rare pleasure of actually being able to solve this problem.
I tried directly modify the custom_components/shelly/manifest.json’s mention of the mqtt version directly to 1.6.12 which kinda worked but still had problems.
Then - I noticed my Shelly version was .2 versions behind AND that the integration wasn’t flagged for an update - I manually updated it to the most recent 3.5 shelly and now it works.
Indeed, just installed the update and have it running again :wink:
Thanks a lot!
This approach works for me too, thanks.
Same error after installing 2025.3:
Integration error: shelly - Requirements for shelly not found: [‘paho-mqtt==1.6.1’].
Repaired it by editing /homeassistant/custom_components/shelly/manifest.json and changing “paho-mqtt==1.6.1” to “paho-mqtt==2.1.0”
Great! Worked for me!
Thanks this fix worked for me and seemed to fix a few other Bluetooth issues at the same time by coincidence or not, I’m not sure.
