For the zigbee/thread connectivity, what other device options do you get after pairing it? I don’t see detach relay yet from the screenshot
I tested Zigbee with firmware from September 2024. Nothing else was available then. I don’t know what firmware new devices are sold with. But… don’t expect much.
I have received mine Gen4 1PM minis.
There are few caveats:
- In ZigBee mode BLE Proxy doesn’t work
- Input state is not exposed via ZigBee
I noticed that the consumption type is not honored when using Zigbee. Is this a Shelly or a Zigbee issue?
Edit: fixed incorrect spelling (consumption not consumation lol)
Consumation? please elaborate
I have tried opening a ticket with feature request on Shelly help desk with request to Input state reporting over ZigBee but all my tickets were closed without any feedback.
I kindly ask you to got to shelly website and open a ticket with the request to add it in the next firmware update. You can make it here Submit a ticket :
Without Input state reporting these relays are not so good for smart home zigbee network
Only Shelly can change this. And this is not an issue, this is a feature request ![]()
To be frank, this is not a feature request to me. When using Wifi, and adding the consumption type “light”, HA exposes light entities. Why should it be a feature request to get the same functionality when using a different protocol?
But thanks for the link to the ticket system. Will file a ticket and see what the results are ![]()
Edit: again, consumption not consumation
filed a bug with Shelly
Please, open a ticket with Technical support → report an issue, instead of Device and Feature requests, since they are only periodically reviewed and doesn’t stay open tickets.
That’s what I did
ticket 166827
So i got one of those new Shelly mini 4’s.
Can you use wifi and zigbee at the same time?
I also hope shelly will make the zigbee pairing possible by UI or api, and not by pushing the button
Agree. I simply cannot set it in pairing mode. Nailing the 5 press change to zigbee firmware is as far as I got.
@Mosher @h1ghrise1337 I also have the Gen 4, but currently set up with Matter. Since you have it set up with ZigBee, are you please able to confirm whether a) they can be added to Philips Hue app and b) whether there can be an automation set in detached mode that control the Hue bulbs rather than turn off the power?
Even I do have Hue lights around my house, I have ditched Hue ecosystem in favor of Z2M+HA. So I cannot provide you with the intel you are looking for.
Sorry
However I run mines in detached mode to control Hue lights.
As of now Input state is not published on ZigBee which is a shame and we need to push Shelly to change this. For now I use Input state from WiFi
I experienced an inconsistent behavior.
Sometimes, when switching to zigbee, the Wifi Radio still was active and the was device reachable via it’s IP Adress. Sometimes, when switched to zigbee, wifi immediately was not available anymore.
@dean.1 I cannot test as im not using any Hue products.
BUT: in official shelly forums, this topic is discussed. It’s not working as Shelly has not implemented ZLL. So devices will expose as a simple switch.
Any chance Cluster 0xFC02 (Wifi Setup Cluster) will be supported by ZHA in the near future?
Shelly WiFi Setup Cluster | Shelly Technical Documentation
Would be great if you could get the switch state.
I raised a zha-quirks feature request for that:
[Device Support Request] Shelly 1 (PM) Gen 4 Specific Clusters · Issue #4125 · zigpy/zha-device-handlers
I installed 2 of these
1 in Zigbee mode with ZHA. With 1.5.99 firmware. I can’t access the BT or WiFi when Zigbee is on ![]()
1 in matter mode. With 1.6.2 firmware. Well, I can’t get this to switch to Zigbee. I have done the 5 click thing almost a 100 times.
I’m gonna leave them same as they are and use one for BT proxy and other as Zigbee repeater.
The documentation is very poor. The videos talking about this do not mention the firmware update disables Zigbee switching nor about how you loose BT and WiFi with ZB
