I have four Shelly H&T sensors integrated using MQTT. I have them configured to also report battery level. I have an issue where the battery will show unavailable in the dashboard. But temp and humidity are reporting fine. Eventually the battery will start showing again but then it will happen again. I wanted to see if anyone else has seen this and if they did were you able to fix it. Thanks in advance.
