Shelly H&T update
Hi guys, I’ve just set up a Shelly H&T sensor into my HA instance, but I’ve seen that the entity doesn’t get updated, while on Shelly Cloud the sensor gives updates. Why?
I’m using HA 2022.11.2 as docker container (linuxserver).
Thanks!
Marco
Hi
Did you find any solution? Since i have the same issue, worked perfect in 3months but suddenly stopped working
Which generation? 1, 2, 3? if 2 or 3 did you activate websockets for generation 2,3?
Sorry about late answer. The issue was a firewall thing.
After an update the firewall started to block without logging it, a bit more timewasting to find the issue when the logs is missing.
