Shelly HT Integration broken with some 2025 build?
I have a 1st generation Shelly H&T (Shelly H&T White – Shelly Europe) which had been reporting data in to HA perfectly fine for several months. A few days ago HA stopped showing its data. I believe it was after I upgraded my installation to the latest Docker image. But unfortunately I only realised the loss of data after a few days. So I’m not 100% certain.
I checked the logs: the Docker container’s “starting” timestamp (last time I upgraded it) is about 14 minutes after the last reported value. Given it would usually report data about every 10 minutes, it really looks as if the data stopped being recorded after installing 2025.1.2.
The device itself still seems to be working just fine: I have a legacy system which is still fed with the data, and that is getting regular updates. I’m also able to connect to the HT when it’s not asleep.
The other Shellys I have (Flood, HTG3) are still working as expected.
Just updated to 2025.1.3, and my Shelly data is back. Let’s keep fingers! Thanks a lot to whomever looked into this.
Maybe some other cause? My 3 HTs worked without an issue on 2025.1.x where x = 0, 2, 3 (skipped .1)
At least it’s working again.
(edited to add : also in a docker container, on a Synology NAS)
Unfortunately it didn’t last for long: after 2-3h the signals disappeared again :unamused:.
Do you also have 1st generation devices? I am using half a dozen Shelly devices, but only the 1st gen HT doesn’t work as expected with HA.
:)) thought they were but, on checking, they are Gen2 (square face, with display).
Hi, I have the same issue. My Shelly H&T are working fine with Shelly Cloud but became unreliable with HA since January.
I looked to a solution using the Cloud (far from ideal) and two methods are suggested: by a MQTT broker or with curl.
