Shelly I3 with ESPHome
I just flashed a Shelly I3 with an ESPHome image (see here).
Pretty fickle thing to do without the fitting connector! But after some trial and error with a small pair of tweezers I got it going. Now I can OTA-update from the ESPHome plugin in HA.
Bootstrapping is such fun!
The three inputs work and show up in the UI.
The LED is not available yet.
Wait till you hit the timing error and floating issue… I don’t want to take put the fun… but for me that is a major issue…
Wifi hickup? Toggle/trigger input… I live with it… but its far from ideal.
Oh and btw. You can do all flashing ota by using intermediate tasmota firmware before flashing esphome…
As @sender says, you flash ota with tasmota
http://shellyip/ota?url=http://dl.dasker.eu/firmware/mg2tasmota-ShellyI3.zip
If i may help, this is my “most stable yaml”…
substitutions:
  devicename: shelly_i3_01
  ssid: ssid
  password: !secret ssid_wifi_key
esphome:
  platform: ESP8266
  board: esp01_1m
  esp8266_restore_from_flash: true
  on_boot:
    then:
    - delay: 10s
    - globals.set:
       value: "true"
    - globals.set:
       value: "true"
wifi:
  ssid: "IOTDOM"
  domain: !secret domain
 #use_address: 192.168.6.41
  ap:
    ssid: "${devicename} Fallback Hotspot"
    password: !secret Fallback_Hotspot
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
web_server:
  port: 80
time:
  - platform: sntp
globals:
   - id: can_switch1
     type: bool
     restore_value: no
     initial_value: "false"
   - id: can_switch2
     type: bool
     restore_value: no
  - platform: wifi_signal
    name: "${devicename} - WiFi Signal"
    update_interval: 600s
  - platform: uptime
    name: "${devicename} - Uptime"
    icon: mdi:clock-outline
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO12
      mode: INPUT
    name: ${devicename} Input 1
    filters:
      - delayed_on_off: 200ms
#    on_press:
#      then:
#        - switch.toggle: switchid1
    on_press:
      then:
        lambda: |-
          if(id(can_switch1)){
            id(switchid1).toggle();
  - platform: gpio
    pin:
      number: GPIO14
      mode: INPUT
    name: ${devicename} Input 2
    filters:
#    on_press:
#      then:
#        - switch.toggle: switchid2
    on_press:
      then:
        lambda: |-
          if(id(can_switch2)){
            id(switchid2).toggle();
  - platform: gpio
    pin:
      number: GPIO13
      mode: INPUT
    name: ${devicename} Input 3
    filters:
      - delayed_on_off: 100ms
switch:
    name: "${devicename} Switch 1"
    optimistic: true
    restore_state: true
    name: "${devicename} Switch 2"
    optimistic: true
    restore_state: true
  - platform: restart
Thanks for the tips!
Those problems you mention, are they specific to the I3, Shelly or even ESPHome?
I3 specific
Is there still issues with it ?
I resolved my issues externally via node red. Only trigger on specific state changes and ignore unwanted ones. I can live with it now.
Thank you for feedback
Can you provide some details how you solved this? I have a couple of i3s flashed with esphome. They are much more stable than with stock firmware (a lot of wifi issues).
But now I have “phantom” button presses.
I control my shutters with the i3s and now in the middle of the night my shutters open - or close …
Very annoying - but i´m struggeling with logging on esphome.
At the moment i´m considering tasmota with mqtt or replacing them :frowning:
If Phantom presses are picked up by node red filter them out. In the trigger node where the i3 is selected click all boxes to ignore all state changes other than on and off.
