CoAP multicast is already merged and will be available in HA 0.118.
From HA 0.118 release notes: The Shelly integration now has real-time status updates, which has been implemented by [@thecode]! Does that mean input state binary sensor is up and running in 0.118?
No. Check 3 posts above your one.
Bieniu posted a link to a pull request for that one. It is already merged. Maybe for a 0.118.x release?
Nope, new feature PRs go to the next release, so we have to wait for HA 0.119.
Any idea when 0.119 will be released?
December 13
BTW there is a calendar on the developers page: https://developers.home-assistant.io/
Ok, with the latest version of HA I see binary sensors created for the shelly devices with a input set to detached. But they are not available somehow.
On the shelly integration page you have to listen to a shelly.click event.
So what is the integration? The shelly.click event or the binary sensors? If it is the latter, how do I get the sensor to be available in HA?
I tried both ways, unfortunately none is workingā¦
Has anyone got the binary sensor working? I just updated HA to the latest version and I see there are binary sensors available, but not the binary sensor for the state of the switch. There is a sensor for, input, rssi, cloud, and firmware. Iām not sure what the input sensor does, but it does not change states with the reed switch open or closed.
Iām not sure what you are missing : recent ha release provide entities like binary_sensor.shellydimmer2_e098069qq3d4_channel_2_input. And they are changing state when the button is pressed.
My problem is that this state change is slow : short pressing the button often misses the event in HA. I set up a simple automation toggling an another shell by the off-on state change of the input wired to a pushbutton. Firmly pressing the button works fine, but thatās not naturalā¦
I have a Shelly 1 as a garage door switch. 12v power and a magnetic reed switch to tell if the door is open or closed. The input state doesnāt change when the switch is open or closed. Is the input sensor what should be changing from on to off based on the switch being open or closed?
Does someone also experiencing CoAP issues? None of my Shelly devices gets autodiscovered. Must say dat i donāt care, i can add them by hand. But then CoAP does not work, the state change is super slow (default 60sec). Must say that my Shellyās are on other VLAN then Home Assistant, but mDNS works fine with Esphome, which are also on that same VLAN and does not have any delay. Iām using Ubiquiti stuff.
Thanks. Good post. The devices get autodiscovered now, but responds slow ā¦ running v1.9.3-rc3.
Iām a bit out of options on my end iām afraidā¦
Debug log for Shelly integration please.
Do you mean this part of the log:
2021-01-05 12:10:12 DEBUG (MainThread) [homeassistant.components.shelly] Manually updated Shelly Living Room data
2021-01-05 12:10:14 DEBUG (MainThread) [homeassistant.components.shelly] Manually updated Dimmer Master Bedroom data
2021-01-05 12:10:17 DEBUG (MainThread) [homeassistant.components.shelly] Polling Shelly Device - Dimmer Kitchen
2021-01-05 12:10:17 DEBUG (MainThread) [homeassistant.components.shelly] Manually updated Dimmer Kitchen data
2021-01-05 12:10:17 DEBUG (MainThread) [homeassistant.components.shelly] Finished fetching Dimmer Kitchen data in 0.015 seconds
2021-01-05 12:10:27 DEBUG (MainThread) [homeassistant.components.shelly] Manually updated Shelly Living Room data
2021-01-05 12:10:29 DEBUG (MainThread) [homeassistant.components.shelly] Manually updated Dimmer Master Bedroom data
2021-01-05 12:10:43 DEBUG (MainThread) [homeassistant.components.shelly] Manually updated Shelly Living Room data
2021-01-05 12:10:44 DEBUG (MainThread) [homeassistant.components.shelly] Manually updated Dimmer Master Bedroom data
2021-01-05 12:10:50 DEBUG (MainThread) [homeassistant.components.shelly] Polling Shelly Device - Dimmer Kitchen
2021-01-05 12:10:50 DEBUG (MainThread) [homeassistant.components.shelly] Manually updated Dimmer Kitchen data
2021-01-05 12:10:50 DEBUG (MainThread) [homeassistant.components.shelly] Finished fetching Dimmer Kitchen data in 0.014 seconds
2021-01-05 12:10:58 DEBUG (MainThread) [homeassistant.components.shelly] Manually updated Shelly Living Room data
2021-01-05 12:10:59 DEBUG (MainThread) [homeassistant.components.shelly] Manually updated Dimmer Master Bedroom data
2021-01-05 12:11:13 DEBUG (MainThread) [homeassistant.components.shelly] Manually updated Shelly Living Room data
2021-01-05 12:11:14 DEBUG (MainThread) [homeassistant.components.shelly] Manually updated Dimmer Master Bedroom data
2021-01-05 12:11:23 DEBUG (MainThread) [homeassistant.components.shelly] Polling Shelly Device - Dimmer Kitchen
2021-01-05 12:11:23 DEBUG (MainThread) [homeassistant.components.shelly] Manually updated Dimmer Kitchen data
2021-01-05 12:11:23 DEBUG (MainThread) [homeassistant.components.shelly] Finished fetching Dimmer Kitchen data in 0.013 seconds
2021-01-05 12:11:28 DEBUG (MainThread) [homeassistant.components.shelly] Manually updated Shelly Living Room data
2021-01-05 12:11:29 DEBUG (MainThread) [homeassistant.components.shelly] Manually updated Dimmer Master Bedroom data
2021-01-05 12:11:43 DEBUG (MainThread) [homeassistant.components.shelly] Manually updated Shelly Living Room data
Edit: Looks like itās manually updating, so COAp does not work. They did get autodiscovered right away but after that itās still updating manually.
Manually updated...
means that integration getting data from CoAP multicast. Polling...
means that integration didnāt get data from multicast on time and the device was polled for data. You have some problems with multicast in your network.
Forgot to add to my post: Only āDimmer Kitchenā is connected to diffrent VLAN and has therefor issues with Multicast. The other two devices are connected to the same VLAN as Home Assistant. They work as expected.
I have no clue what holds back the operation of Multicastā¦ Iām going to investigate further with firewall rules.
I got it figured out. Apparently the reed switch was bad. I replaced it and the state change is almost instant, no lag at all. Discovery doesnāt work for me but thats not a big deal. I can add devices one at a time when I install them.
