I can put these on my Dashboard as an Entity card.
I can create a button card and open and close the garage door .
The problem I have is that I have no indication of the state of the reed switch so I can tell if the garage door is open or closed. We have a puppy that tries to escape and being able to see if my garage is open or not is important. I have seen other users get a sensor or binary_sensor of the reed switch state, usually with the name ending â_inputâ .
And also I have seen extra sensors that give the switches RSSI output, usually the strength of the wifi signal in dBm. But I dont have that either.
I feel iâve done something wrong and missing a few features of the Shelly switch.
Do you know how i get get those features enabled or where to check to see what the issue might be?
I do have Shellies Discovery and Mosquito MQTT installed and can see the Shellies Announce and Shellies Discovery Entitites. I did the full install from Gitghub
Where can I see those logs?
I suspect I have over installed and conflicts are running.
Iâve decided to start afresh on my Shelly1 Switch and remove all Shelly related intergrations.
Then went with built in HA intergation for Shelly, turned off MQTT on the switch itself, and now my âinputâ is there and i can see itâs State âonâ or âoffâ according to the reed switch state. Can also control the switch itself. Thanks for recomendation.
sorry to re up that thread, but I try to do what you did with a shelly 1, a garage door, and home assistant, but I cannot get the âsensorâ to work, even in the shelly app: it doesânt display the state of the garage door. (open or close)
Could you please detail the wiring and the settings of your shelly ? ( button type, other relevant options âŚ)
Thank you very much !
Not using a sensor hanging off the Shelly1. Its just there as a switch not a sensor.
Iâm using a seperate Aqara door and windows sensor to detect if the garage door is âclosedâ or ânot closedâ. I did have the Shelly1 sensor teling me if door was âfully openâ or not âfully openâ. As i have small dogs i need to know if fully closed or not.
Another Aqara sensor on the side gate controls whether the Shelly1 can be triggered or not. If gate is open the Shelly cannot be triggered to open the garage door. (stops dogs running away)
