Hello. I appreciate the development and support and have a question regarding the inbuilt Shelly integration.
I have two Shelly Pro 3 EMs (I believe generation 2?) running the latest stable firmware (1.1.0). They live on a different subnet from my HA server (2024.1.5) and have a static IP addresses. Only HTTP (over a nonstandard port) is forwarded to the Shellys.
Following the instructions at Shelly - Home Assistant for gen 2/3 devices, I enabled outbound WebSocket and entered the HA address (ws://IP:PORT/api/shelly/ws).
When I try Add Integration to connect to the Shelly (IP:PORT), I get an “Unexpected Error”. In the logs, this looks like the port is not being handled properly: “ValueError: ‘IP:PORT’ does not appear to be an IPv4 or IPv6 address”.
If I forward port 80 to the Shelly, I can connect and add a device and entities, but I have only one port 80 on the firewall and multiple Shellys. How do I need to enter the IPs with the nonstandard ports in order to connect to multiple Shellys?
Thank you.
