Shelly integration can't login
I’m trying to add the Dimmer 2 to Home Assistant using the Shelly integration having updated the firmware I get “Invalid authentication”
Is there some other account at a different URL that I need to set up? I’ve changed my password to something simpler. I’m using my email address as my username is this correct?
I can login to https://my.shelly.cloud/ with my email address and password with no problem
I found out myself, so I hope this helps anyone else with the same issue.
The login details are for the Shelly Dimmer 2 itself. NOT your cloud login
