Shelly Integration - Detached Switch
I just setup a Shelly 2.5 over the Home Assistant Integration (So no MQTT).
The Shelly is connected with a few lamps (Channel 1) and a motion sensor on the SW1 Channel.
I configured the SW1 Channel as a Detached Switch, so I can create better automations.
Now in Home Assistant I can control Channel 1 but there is no binary sensor for the Detached Switch, how do I get the state of the Detached Switch with the Shelly Intergration ?
Thank you for your help ^^
Called Problem was fixed/integrated in the Shelly Integration in Version 202012.
I was having Shelly 1L modules working great as detached switches until I updated HA to version 2021.1.3 and OS 5.10. Now Shellys are no more available in HA.
However, both Shellys work properly with the Shelly app. Anyone having similar issues?
