I’m having issues with the oficial Shelly integration.
After the release 2021.3 I’ve added again my shelly door/windows sensor (support for battery devices added in this release), but now there are no entities inside:
Unfortunately no solution found
I’m thinking on delete everything and use ShellyForHass,but I have a lot of Shelly and automatisation, so I preferred to find a solution.
My devices have static IP, firmware: 20210323-105237/v1.10.1-gf276b51
Has anyone found a solution to this? It worked the very first time I added the DW2, but when I deleted and re-added, I now get no entities. It’s driving me mental!
So I’ve done a ton of playing and a ton of logging. Shelly is on latest firmware. I’ve got it set to a specific CoIoT port (5683). If I make device discoverable, it does auto-discover in hassio, but only the device - not the entities. If I actually manually move the sensor, I get entries like this in the log:
2021-04-25 13:48:33 DEBUG (MainThread) [homeassistant.components.shelly] Manually updated shellydw2-483FDA8253F5 data
I cannot, for the life of me, get the entities to auto-create, even though they’ve been there in the past (on first setup). Any tips?
I’m getting this as well. Previously working fine, then the sensor stopped updating so I removed and re-added it. Now the DW gets detected, but there are no devices/entities.
I have tried the workaround suggested - removing and deleting references from the device registry - but it still doesn’t find any entities when re-added.
I’ve tried everything today - removing all entities and reinstalling using both the native integration and shelly for HASS. Just wont’ play ball for some reason.
As a workaround, I have enabled MQTT on the DW2 and set up MQTT sensors for now.
After easily integrating two Shelly Plug S I bought a Shelly Door Window sensor and a Shelly Flood sensor.
Both are found by the Shelly integration and all entities are listed with correct values initially, but then the entities are never updated.
I tried all sorts of combinations of settings, but no luck
I had the same problem and setuped also MQTT, as with version 2012.12.0 all sensor has to be rewritten, I tested another approach.
When I got my shelly TRV there was an integration hint that you must use CoIoT.
I setuped Enable CoIoT and for the CoIoT peer I use $HomeAssistantIP:5683 e.g., 192.168.1.1:5683.
That’s working fine for me.
