I had to do some work on my network and the IP address of HA changed. Same IP range, just a different IP address.
Everything works except for my Shelly integration. It “fails to connect” and the devices show as unavailable.
The individual devices are connected to my network via wi-fi 1 in the settings on the Shelly devices.
This is what I’m getting in the logs when I try to reload the devices.
Thoughts on what’s going on?
tom_l
2
Are you using Gen 1 Shelly devices?
Did you set up CoIoT in these devices?
If so you need to change the HA server address in that setting on the devices.
I don’t think they’re first gen. I don’t see that setting anywhere. I’ve got a Shelly Dimmer 2 and a Shelly Uni. My web screen looks like this.
apreick
5
Shelly Dimmer 2 and Shelly UNI are GEN 1!
ColoT setup you find when open the IP direct in Browser (WebUI)
