I have HomeAssistant set up in a docker container, using the default in the documentation:
docker run -d \
--name homeassistant \
--privileged \
--restart=unless-stopped \
-e TZ=Australia/Sydney \
-v /opt/homeassistant_config:/config \
--network=host \
ghcr.io/home-assistant/home-assistant:dev
I’m trying to setup a Shelly Motion 1 with the HA instance.
I have enabled CoIoT on the Shelly Motion, and I am pointing it at port 5683 on the HA instance IP address.
I checked on the Docker host, and it is listening on port 5683 UDP - I’m assuming privileged and network=host should take care of that.
The HA instance does discover the first Shelly Motion 1 - however, after adding it, it doesn’t appear in devices. And then under integrations I see:
Does anybody know what might be happening, or how I might debug this further?
