Hi, I ecxperience this way too often … I do not know how to troubleshoot this.
In Android app some devices are online and fully working, but in Home assistant are UNAVAILABLE
In Android app some other devices are online and fully working, and they work correctly also in Home assistantr.
How can this happen. Any hint on how to solve this?
EDIT: when I REBOOT the device from the android app, after around 30 seconds it then comes back to life in Home Assistant
Again after I rebooted many Shelly that were offline, they went all online, now some again are back offline in Home Assistant (but online in Shelly app) … not alwayts the same Shelly, seems random …
All static IP addresses at router level (since 20 years I do assign a static IP to all new devices). Now I will try to put a static IP address (the same) also at the Shelly level … perhaps)
BTW if this is not working I want to use MQTT … but where is it under the Shelly app … it disappeared after new UI
That’s intereseting, as in my case it’s quite the opposite. The Shellies work perfectly in HA (they are also very responsive and quick), but are most of the times offline in my Android app (PM1 is always offline, no way I can control it from the app).
