Hi. I am using a Shelly Plug S with Home Assistant. I am able to see the sensor readings and to turn the plug on and off from HA.
But there is a small physical button on the plug, that allows manually switching the plug on location. I would like to
Prevent this manual operation and only let the plug be handled from HA.
Trigger a custom HA automation when the button is pressed.
How can I go about this? I tried Googling for answers but the terms “shelly” and “button” always divert me into stuff about a different device, the Shelly Button. I need answers for the small button on the Shelly PlugS device.
I think that is not possible. At least I haven’t read any information about it. In the Shelly Admin Inferface I did not find an option to change this button. Also, this button is not available in HA Shelly integration.
I am not familiar with ESPHome, but I am familiar with Tasmota, and I would know how to do it with Tasmota (which, BTW, is very easy to flash over the air on these Shelly’s)… but I actually started using HA so I could avoid the hand-made stuff and the flashing… especially on this system that I am setting up for other (less technical) people to use.
So should I conclude from your suggestion that this is not possible with the default Shelly firmware and HA? What a pity.
Hi! Are there any updates on this?
Shelly Plus 2PM, working in detached mode, exposes the button input in HA which is quite useful. I’m using it for turning on/off smart LED strips.
I’m trying to use button of my Shelly Plus Plug S to do something else besides turning on/off power but without luck so far. Up to this point I’ve been quite happy with Shelly devices so I would like to avoid flashing.
