Shelly Plus 1 missing binary sensor
Hi all,
i switched from the ShellyForHass to the original Shelly integration.
Everything is working fine except my Shelly Plus 1 for controlling my garage door.
I have connected a magnetic sensor to it. So I can see if the door is open. I can see the state in the Shelly App. And also with the old ShellyForHass integration there was a binarysensor in HA for this.
But now this sensor was not created again. I have searched and tried a lot, but I can’t find my problem.
Perhaps someone has a solution for me :slight_smile:
This is everything I get for this Shelly in HA:
In the Shelly App it is configured as a Switch in Detached Mode.
Thank you for your help :slight_smile:
Did you manage to make it work? I tried so hard and I can’t get the status from the magnetic sensor… Open and Close garage but nothing changes…
can you share your code if it’s working please?
Any luck with this? I had to switch from ShellyForHass to the native integration because it stopped working in 2024.12.x. I’m pretty pissed off that the native integration does not appear to expose a binary sensor.
