substitutions:
device_name: "Shelly Plus 1PM"
current_res: "0.001"
voltage_div: "1825"
globals:
- id: max_temp
type: float
restore_value: no
initial_value: '80.0'
- id: max_voltage
type: float
restore_value: no
initial_value: '250.0'
esphome:
friendly_name: ${device_name}
platformio_options:
board_build.f_cpu: 160000000L
esp32:
board: esp32doit-devkit-v1
framework:
type: esp-idf
sdkconfig_options:
CONFIG_FREERTOS_UNICORE: y
CONFIG_ESP32_DEFAULT_CPU_FREQ_160: y
CONFIG_ESP32_DEFAULT_CPU_FREQ_MHZ: "160"
logger:
level: ERROR
api:
encryption:
key: !secret api_key
ota:
password: !secret ota_password
wifi:
ssid: !secret wifi_ssid
time:
- platform: homeassistant
output:
- platform: gpio
pin: GPIO26
switch:
- platform: output
output: "relay_output"
internal: true
lambda: 'return id(relay).state;'
turn_on_action:
- if:
condition:
and:
- sensor.in_range:
below: 80.0
then:
- switch.turn_on: relay
turn_off_action:
- switch.turn_off: relay
number:
optimistic: true
min_value: 1.0
max_value: 3600.0
step: 0.1
restore_value: true
entity_category: "CONFIG"
optimistic: true
min_value: 0.001
max_value: 16.0
step: 0.001
restore_value: true
binary_sensor:
- platform: gpio
pin: GPIO4
on_press:
then:
- switch.turn_on: "output"
on_release:
then:
- switch.turn_off: "output"
filters:
- delayed_on_off: 50ms
icon: mdi:flash-alert
entity_category: "DIAGNOSTIC"
device_class: problem
lambda: 'return id(power).state > id(max_power).state'
lambda: 'return id(ampere).state > id(max_amp).state'
lambda: 'return id(voltage).state > id(max_voltage)'
icon: mdi:thermometer-alert
lambda: 'return id(temperature).state > id(max_temp)'
- platform: ntc
sensor: temp_resistance_reading
name: "Internal Temperature"
unit_of_measurement: "°C"
accuracy_decimals: 1
icon: "mdi:thermometer"
calibration:
b_constant: 3350
reference_resistance: 10kOhm
reference_temperature: 298.15K
on_value:
then:
- if:
condition:
lambda: 'return id(temperature).state >= id(max_temp).state;'
then:
- switch.turn_off: "relay"
- platform: resistance
sensor: temp_analog_reading
configuration: DOWNSTREAM
resistor: 10kOhm
- platform: adc
pin: GPIO32
attenuation: 11db
- platform: adc
pin: GPIO33
attenuation: 11db
filters:
- multiply: 8
- platform: hlw8012
model: BL0937
sel_pin:
number: GPIO23
inverted: true
cf_pin: GPIO5
cf1_pin: GPIO18
current_resistor: ${current_res}
voltage_divider: ${voltage_div}
current:
unit_of_measurement: A
accuracy_decimals: 3
internal: true
voltage:
unit_of_measurement: V
internal: true
on_value_range:
- above: "250.0"
then:
power:
unit_of_measurement: W
internal: true
on_value:
then:
if:
condition:
lambda: 'return id(power).state >= id(max_power).state;'
then:
change_mode_every: 3
update_interval: 500ms
icon: mdi:flash
lambda: |-
return id(power).state;
update_interval: 2s
icon: mdi:current-ac
lambda: |-
return id(ampere).state;
update_interval: 2s
icon: mdi:sine-wave
lambda: |-
return id(voltage).state;
update_interval: 2s
- platform: total_daily_energy
power_id: power
filters:
- multiply: 0.001
unit_of_measurement: kWh
icon: mdi:flash
- platform: wifi_signal
name: "WiFi Signal Strength"
update_interval: 60s
- platform: uptime
icon: mdi:clock
status_led:
pin:
number: GPIO0
inverted: true
