Shelly Plus 2PM rolling shutter
Hello everyone, I have a Shelly Plus 2PM for my rolling shutter. Switch 0 is down and Switch 1 is up. I still use a rolling shutter switch next to my bed to control the rolling shutter manually but I use automations as well. The power monitoring functionality allows me to know when the shutter is all the way at the top or all the way down as it reads 0 Watt. I want to know the position of my rolling shutter because I want to use it in certain automations. The positions I would need are the following: closed, ventilate 1 (switch 1 on for 3 seconds), ventilate 2 (switch 1 on for 6 seconds), half way open (switch 1 on for 12 seconds) and open (switch 1 on for 25 seconds). Opening the shutter all the way takes 25 seconds and closing takes 22 seconds. Is it possible to configure the Shelly Plus 2PM with the two channels as a cover and know the position in some way? Thanks in advance for your input!
EDIT: I didn’t configure the Shelly properly. I noticed I could select cover as the type instead of switch and that solved everything. The Shelly calibrated itself and now all works well!
