Dear All,
I received my shelly add-on plus today and did installed them already.
I recognized, that the Shelly integration don’t supports the add-on information (temperature, digital-IN, Voltmeter)
Does anybody know how to integrate the sensors/data from shelly add-on plus to HA?
best regards
Erik
push up - does anybody know how/if the add-on will be supported?
appreciate any feedback
//Erik
RonnieLast
(Last of the Ronnies)
January 15, 2023, 12:20pm
3
I wonder if you need to enable the websocket like with the H&T?
opened 01:51AM - 03 Nov 22 UTC
closed 04:01PM - 04 Nov 22 UTC
integration: shelly
### The problem
Had some issues adding a Shelly Plus H&T, I initially forgot to… set outbound websocket but after setting it according to the documentation the device was added but when clicking on it there was no device nor any entities. This was similar to what was described here (#80902). This was solved by instead of using _homeassistant.local_ as the documentation suggests (_for example: ws://homeassistant.local:8123/api/shelly/ws_) I used the IP-address directly instead.
I dunno if it is me misreading the documentation or if there is an actual problem here that needs to be fixed. I did some testing and outbound websocket on the shelly device configuration page is _connected_ when using IP and _disconnected_ when using _homeassistant.local_. A bit odd given that I can use _homeassistant.local_ in my browser without problem and can even ping it in command line.
### What version of Home Assistant Core has the issue?
core-2022.11.0
### What was the last working version of Home Assistant Core?
_No response_
### What type of installation are you running?
Home Assistant OS
### Integration causing the issue
Shelly
### Link to integration documentation on our website
https://www.home-assistant.io/integrations/shelly/
### Diagnostics information
_No response_
### Example YAML snippet
_No response_
### Anything in the logs that might be useful for us?
_No response_
### Additional information
_No response_
Or even a webhook?
This service allows Shelly devices to send HTTP requests triggered by events. Events usually occur when functional device parts change their state (switch toggling, button pushes, sensor readings, etc.). There is a limit of 20 hook instances per...
Thanks for the reply.
Whatever happened - now I can see the voltage from the add-on.
Thanks!
I have the same issue. I attached a reed sensor with the addon plus to the shelly plus 2pm. I get the correct reed inside the shelly app but the addon sensor does not appear in HA.
Is it not supported yet or does it have to be activated somewhere.
Thanks!
Chris
Well mate… what shall I say. Yes I did restart many times but now I checked again and here it is.
Thank you anyhow
RonnieLast
January 23, 2023, 3:21pm
8
Seems to be a common complaint though!
Maybe the best guidance should be to restart HA and wait for the discovery to complete.
brdmind
(TASOS KARAGIANNIS)
April 13, 2023, 1:49pm
9
hello, anyone added the Shelly Plus Add-On to homeassistant as digital input? I can control the input via the shelly web interface but I can not find the entity in homeassistant. I gent entity unavailable.
CyberHome
(Michael)
April 28, 2023, 5:02pm
10
Hello Add-On Users,
I’m realy exited how easy it was to mount the add-on to shelly 2 plus.
Connected currently 4 DS18B20, went also very seamless.
→ Using MQTT and could see the values in Mqtt.Fx already.
Next Stepp → Configuring MQTT Sensors in HA.
maxym
April 28, 2023, 5:07pm
11
or configure it through mqtt and forget about any problems
CyberHome
(Michael)
April 28, 2023, 5:10pm
12
You are right, I did it to often (early times) and forgot how easy… it is meanwhile.
THX for the fast hint.
did anyone manage to configure the temprature with mqtt - yaml?
trying to figure it out since this morning, with out any luck.
Can somebody share the yaml code?
