I want to use a shelly motion sensor to turn on a Shelly 1PM which is connected to the light near the motion sensor. I can select the Shelly motion sensor as the motion sensor input but the Shelly 1PM is not an option for “choose device” or “choose entity”. Interestingly, I do have a Shelly plug that does show up.
I have successfully created an automation manually using the same two devices. I want to try this blueprint because it adds the function of turning off the light after a period of time.
Thanks for any guidance.
