hello,
I cannot transfer the configuration to the shelly pm mini gen3. I was able to flash Tasmota and then wanted to switch to esphome. unfortunately without success.
Does anyone have any ideas? here is my configuration yaml.
ESPHome 2024.5.5
esphome:
friendly_name: esphome_ke_bwwp
esp32:
board: esp32-c3-devkitm-1
flash_size: 8MB
framework:
type: esp-idf
version: recommended
sdkconfig_options:
COMPILER_OPTIMIZATION_SIZE: y
# board_build.flash_mode: dio
advanced:
ignore_efuse_mac_crc: false
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "MxxxxxxxxwRg="
ota:
password: "6xxxxxxxxxxxx5"
wifi:
use_address: esphome-ke-bwwp.xxxx
ssid: !secret wifi_ssid
ap:
ssid: "Esphome-Ke-Bwwp Fallback Hotspot"
password: "mxxxxxxxx7Z"
time:
- platform: homeassistant
captive_portal:
- platform: ntc
sensor: temp_resistance_reading
unit_of_measurement: "°C"
accuracy_decimals: 1
icon: "mdi:thermometer"
calibration:
b_constant: 3350
reference_resistance: 10kOhm
reference_temperature: 298.15K
- platform: resistance
sensor: temp_analog_reading
configuration: DOWNSTREAM
resistor: 10kOhm
- platform: adc
pin: GPIO3
attenuation: 11db
- platform: bl0942
uart_id: uart_0
voltage:
icon: mdi:alpha-v-circle-outline
device_class: voltage
current:
icon: mdi:alpha-a-circle-outline
device_class: current
power:
icon: mdi:transmission-tower
device_class: power
energy:
icon: mdi:lightning-bolt
device_class: energy
frequency:
accuracy_decimals: 2
icon: mdi:cosine-wave
device_class: frequency
update_interval: 5s
uart:
tx_pin: GPIO6
rx_pin: GPIO7
baud_rate: 9600
stop_bits: 1
status_led:
pin:
number: 0
inverted: true
binary_sensor:
- platform: gpio
pin:
number: 1
inverted: yes
mode:
input: true
pullup: true
Thank you
Michael
