Shelly Pro EM 50 not working in Energy Dashboard
Hi, I try to use the Shelly Pro EM 50 to integrate into the Energy Dashboard, but in the “Add consumption” dropdown it is not visible. The drop-down shows “No matching statistics found”
I made a card and it shows the two energy clamps, so it is property integrated.
Is this a bug or is Home Assistant not compatible with the Shelly, how do I proceed?
Thanks for your help
By default, entity active energy is disabled for the Shelly Pro EM, you must activate for it show in list on the Energy Dashboard.
Hello, How do I activate that option?. Thanks.
Open the Shelly device, click on the sensor (you will see it greyed out/disabled) and finally click on the settings icon. There you will find an option to enable it.
