Shelly RGBW2 set up via Shelly integration - only 4 (useless) entities created
When I add a RGBW2, I only get 4 (useless) entities in HA. But no option to control the light (or get the input).
I only got these:
  • binary_sensor.xy_cloud
  • binary_sensor.xy_firmware_update
  • sensor.xy_rssi
  • sensor.xy_uptime
In the Web Interface I can control the lights and everything.
I tried 4 pieces, all have the same issue.
I tried with FW 1.9.0 and 1.10.3 in Color Mode
I tested with HA-core 2021.3 / 2021.4 / 2021.4.2 / 2021.4.3 / 2021.4.4
All other Shellys work fine.
Thanks,
Radon
Hello any resolution to your problem, managed to run into the same issue?
I’ve seeing the same issue
HA 2021.9.5
RGBW2 FW: 1.11.4
maybe it has worked in the past: Shelly RGBW2 - make RGBW control without MQTT
edit: found this issue: https://github.com/home-assistant/core/issues/41560 but haven’t tried the solution yet
A couple days later I switched to MQTT. And I never tried again with the integration.
There it’s working everything. Just the “effect list” is with 1, 2, 3, … instead of the names.
But it works for me.
