Hey everyone, I have an LED strip that has only RGB, no white. How do I use that properly? I’ve wired it according to the docs. 12V, R, G, B. White is unconnected.
In the Shelly console I can’t seem to find a setting that allows for RGB only strips. It only has white only and RGBW.
The behavior of the LED strip integration with Home Assistant seems to expect a white component. I can see this especially when using color temperature. Warm is yellow, cold is completely off.
How do I have to configure all of this to make it run as expected?
Thank you!
