manustar
(Manuel)
June 14, 2021, 9:58am
1
Hi to all, i have one prblem, i’m configure the shelly 2.5 in roller mode with mqtt (create cover.yaml) and set the position_open: 12 - position_close: 95.
but when i call “google” for closed/open the position is not respected.
this my cover
- platform: mqtt
command_topic: "shellies/shellyswitch25-TAPPSALONE/roller/0/command"
position_topic: "shellies/shellyswitch25-TAPPSALONE/roller/0/pos"
set_position_topic: "shellies/shellyswitch25-TAPPSALONE/roller/0/command/pos"
availability_topic: "shellies/shellyswitch25-TAPPSALONE/online"
payload_available: "true"
payload_not_available: "false"
qos: 1
retain: false
payload_open: "open"
payload_close: "close"
payload_stop: "stop"
position_open: 95
position_closed: 12
manustar
(Manuel)
July 17, 2021, 10:47am
3
i don’t know the problem in thi configuration
koying
(Chris B)
July 17, 2021, 11:13am
4
position_open / positio_closed are inputs . They tell HA that the MQTT cover should considered closed at position 12 and opened at position 95.
If you want to override the open / close commands with specific positions, you’ll need to to define a template switch that, instead of sending open/close commands, sends appropriate set_position commands depending on the state of the template switch.
manustar
(Manuel)
July 17, 2021, 11:59am
5
i would like send comand with google home " hey google close all roller shutter" and the roller go to “position_closed”
koying
(Chris B)
July 17, 2021, 12:15pm
6
I got that.
And I told you above what you’d need to do to achieve that: create a template switch.
Something like:
# Example configuration.yaml entry
switch:
switches:
cover_salon:
value_template: "{{ state_attr('cover.tapparella_salone', 'current_position ')|int > 12 }}"
turn_on:
service: cover.set_cover_position
entity_id: cover.tapparella_salone
position: 95
turn_off:
position: 12
You can also create a full template cover:
manustar
(Manuel)
July 17, 2021, 12:49pm
7
meanwhile, thank you so much for your help. I am a novice and honestly I don’t understand much. I implemented google home without nabucasa and exposed the domains. the roller shutter entity in google home is seen. now I have implemented the template suggested by you and the result is the same, open the shutters goes to 100, close the shutters goes to 0. surely I did something wrong, but I can’t understand how to control the switch template via google home.
this my google home in configuration.yaml
google_assistant:
project_id: the id
service_account: !include file.json
# api_key: !secret api_key_google
report_state: true
exposed_domains:
- light
- switch
- climate
- cover
this my iclude in configuration.yaml
####### FILE CONFIGURAZIONI########
script: !include scripts.yaml
scene: !include scenes.yaml
light: !include light.yaml
sensor: !include sensor.yaml
cover: !include cover.yaml
binary_sensor: !include binary_sensor.yaml
climate: !include climate.yaml
switch: !include switch.yaml
camera: !include cameras.yaml
group: !include groups.yaml
this my cover.yaml
######### TAPPARELLA SALONE######
- platform: mqtt
qos: 1
retain: false
position_open: 95
position_closed: 5
######## TAPPARELLA CUCINA ########
- platform: mqtt
command_topic: "shellies/shellyswitch25-TAPPCUCINA/roller/0/command"
position_topic: "shellies/shellyswitch25-TAPPCUCINA/roller/0/pos"
set_position_topic: "shellies/shellyswitch25-TAPPCUCINA/roller/0/command/pos"
availability_topic: "shellies/shellyswitch25-TAPPCUCINA/online"
qos: 1
retain: false
position_open: 95
position_closed: 5
and this my switch.yaml
switches:
cover_salone:
value_template: "{{ state_attr('cover.tapparella_salone', 'current_position ')|int > 5 }}"
turn_on:
position: 95
turn_off:
position: 5
koying
(Chris B)
July 17, 2021, 12:57pm
8
Does the switch work?
After syncing, you should have an additional HA item in google home
You can give it a nice name (and aliases) via Google Assistant - Home Assistant and possibly hide the mqtt one
Personal examples:
entity_config:
switch.plug_tuya_01:
expose: false
switch.venus_wol:
room: Salon
aliases:
- PC
manustar
(Manuel)
July 17, 2021, 1:36pm
9
koying:
when i tap the switch the cover go to 95% open and i retap the switch no have action
on my google home app i see only cover device
manustar
(Manuel)
July 23, 2021, 10:35am
10
i delete and integrate the google home, but gave the same problem.
I don’t understand the reason for not reading the “position_closed”.
Theoretically when I say to close he should go to read the parameter set via mqtt and not bring it to 0
manustar
(Manuel)
August 5, 2021, 10:49am
11
I cannot understand the reason for the problem, the configuration has not changed and for a short time it worked smoothly.
Now it only reads 0% and 100%
