Since the last update I have Problems with my Shelly Pro3: Call RPC for ShellyPro3 Switch_1 Connection Error, Method:Switch.Set,
This error message comes once or twice a day. Then the Shelly works again. It is connected to the LAN, network works with fixed IP. Do you have any idea what this error is?
Doesn’t anyone have an idea?
I Got same problem with :
Shelly Plug S (firmware: 1.2.3) and Shelly Plus 1 PM (firmware 1.4.4)
very sporadic error: “call RPC for Shelly … Connection error …”
HA core 2024.12.5
integration with Shelly native module
I tried some tests with no success
Activate MQTT via Moskito Broker - 192.168.1.190:1883
Additional info:
Lanscale VPN installed
Trying to fix this problem … no succes
Any Idea ?
Shelly Diagnostic:
“home_assistant”: {
“installation_type”: “Home Assistant OS”,
“version”: “2024.12.5”,
“dev”: false,
“hassio”: true,
“virtualenv”: false,
“python_version”: “3.13.0”,
“docker”: true,
“arch”: “x86_64”,
“timezone”: “Europe/Paris”,
“os_name”: “Linux”,
“os_version”: “6.6.66-haos”,
“supervisor”: “2024.12.3”,
“host_os”: “Home Assistant OS 14.1”,
“docker_version”: “27.2.0”,
“chassis”: “vm”,
“run_as_root”: true
“last_error”: “DeviceConnectionError(DeviceConnectionError
RPCCall method=Shelly.GetStatus params=None call_id=1887 result=UndefinedType._singleton”,
“bluetooth”: “not initialized”
