I have installed several Shelly devices last week, and the ones with old - dumb - lights work flawless. The tricky part however is the ones with smart bulbs.
I’ve configarted the Shelly as detached switch and always on. Also activated the input entity in Home Assistant. So far, so good.
When I toggle the switch on the wall, nothing happens. Exactly how it’s supposed to in my opinion. And I’m able to control the smart light bulb via Home Assistant
The problem seems that the state of the shelly, doesn’t change. So it stays on or off. So this situations can occur
- The smart bulb is on, but the shelly input is off
- The smart bulb is off, but the shelly input is on
- The smart bulb is on and the shelly input is on
- The smart bulb is off and the shellu input is off
So in two conditions, the state is equal, in two situations, it’s different. I do however want to be able to control the smart bulb, also via the switch (for if someone accidentally flips the switch). Is there an easy way to do this? Or do I have to build a couple of automations with if/else statements?
- if the switch is off and the light is on and switch goes to on switch the light off ← something like that?
Hope someone here has some easy trick for this =)
Thanks!
