Recently updated to 2033.6 and since one of my Shelly (dimmer 2) has this error:
This entity is no longer being provided by the shelly integration.
Any thoughts on the fix? Thanks
Have you reboot the Shelly?
Can you reach the WebUI over the IP?
Tardis calling home.
Mine is still working fine (2023.6.3)
I can reach the IP fine, rebooted from there with no joy.
My update has messed my set up up, sometimes I can’t reach the server
How can you reach the ip but not see the web page?
I can reach the webpage through the IP no problem.
Also might be with mentioning also. My local HA is unreachable. Not connecting at all.
I can reach HA through the Nuba Cloud though.
Sounds like the IP address of HA has changed.
Strange as it is still the same and occasionally connects but is clunky as hell.
Solved: did a full reboot of my network… solved it. Always the simplest of things!
