Shelly TRV MQTT settings
I’m trying to add Shelly TRV’s with MQTT. With Shelly plugin bulk actions are not safe (some devices do not change temperature) I switched to MQTT. Thats working well so far, but I’ve a problem with device state/mode. Im using this config:
  - name: "Thermostat NAME"
    unique_id: trv-TRVID
    modes:
      - "off"
      - "heat"
    min_temp: 4
    max_temp: 31
    temp_step: 1
    precision: 1.0
    temperature_unit: "C"
    icon: mdi:thermostat
    mode_state_topic: shellies/trv-TRVID/info
    mode_state_template: >
      {% if  value_json.thermostats[0].target_t.value > 4 %}
         heat
      {% else %}
         off
      {% endif %}
    current_temperature_topic: shellies/trv-TRVID/info
    current_temperature_template: "{{ value_json.thermostats[0].tmp.value }}"
    temperature_state_topic: shellies/trv-TRVID/info
    temperature_state_template: "{{ value_json.thermostats[0].target_t.value }}"
    temperature_command_topic: shellies/trv-TRVID/thermostat/0/command/target_t
  - name: "Thermostat NAME Ventil"
    state_topic: 'shellies/trv-TRVID/info'
    value_template: '{{ value_json.thermostats[0].pos }}'
    unique_id: trv-TRVID_valve
    icon: mdi:pipe-valve
    unit_of_measurement: '%'
  - name: "Thermostat NAME Batterie"
    value_template: '{{ value_json.bat.value }}'
    unique_id: trv-TRVID_batterie
    icon: mdi:battery
My problem is that the mode is not set correctly (heat is only when changing the temperature, I think this is the optimistic mode feature) and I’ missing the settings for off and Low. Can someone give me more information how to implement the missing part ?
