Shelly TRV
I have renamed the profiles for my Shelly TRV in its web UI but they are not reflected in Home Assistant.
Seth /0^0\
I have read this post and found no actionable item. Standoff engaged! :slight_smile:
PS. Just go in and rename them in HA :+1:
Thanks, nice easy solution BUT exactly how do I do that, I can find no way.
Here’s the first of my profiles in Shelly webUI:
Here’s what I see using the HA (official) integration, it’s called a preset there NOT a profile there:
Full screen dump:
trv_shellyui
Seth /0^0\
Ah, see that’s a different problem (i think)!
Are you using the stock Shelly integration, MQTT or another method?
If the first, does reloading the integration make the preset show up?
crllogic,
I think you think correctly. :slightly_smiling_face:
I am using the ‘stock’ Shelly integration.
I have just reloaded the integration as follow:
° — CONFIGURATION,
° — Devices and Services,
° — Shelly integration,
° — Selected the Shelly TRV (I have only one),
° — Press the three vertical buttons,
° — Pressed ‘Reload’.
Nothing has changed.
Additionally, I have done a Configuration Check and a ReStart, no change.
I suppose the next thought might be removing the TRV from HA and then re-adding it?
Oh, and what version of HA?
OK … I do that now …
Couple other thoughts.
  1. Have you configured unicast CoIoT?
  2. Even if it doesn’t show in lovelace, can you call the preset using a service or see it in devtools?
Patience crlogic,
° — I have DELETED it from the Shelly integration.
° — I have been to the Shelly web UI and rebooted the Shelly.
° — I have been to the other end of the house and press buttons on the TRV.
° — I have restarted HA and got a notification,
° — I have add the TRV to the Shelly integration but no DEVICE or ENTITY has appeared,
(I’ve seen this before ???).
° — So I restarted HA AGAIN and the TRV DEVICE and ENTITY are present …
AND so are the CORRECT names for the profiles / pre-sets.
Thanks so much for you assistance crlogic.
I shall mark it as resolved.
Seth
Glad to hear!
(I never thought about devtools.)
Yeah I wasn’t sure if it was the integration or a lovelace bug - devtools is life :slight_smile:
I am trying to integrate a Shelly TRV into Home-Assistant (stock integreation) but it fails every time. I tried with different TRVs (different IPs) but all I get is "Failed to connect"
What am I missing here?
It ‘sleeps’, I think, same problem here. If you press the button it will wake up, not much use though.
I have the same problem since they arrived.
Till yet I didn’t get them integrated into H.A…
Did you find the problem?
