I am using a Shelly Uni to get my Pool water temp and Pool Pump pressure using the ADC Voltage. Temperature works perfect in Home assistant. But the ADC Voltage is not being picked up by Home Assistant. If i go to the Uni’s web interface I can see the voltage change with rise and fall of pressure sensor but Home Assistant just reads 0. Anyone using the shelly uni this way or similar or have trouble seeing the voltage in home assistant.
Figured it out. Evidently HACS Shelly integration does not grab the Voltage in HA. I deleted HACS integration and used the native Shelly integration and it works great now.
hey buddy, i purchased a Shelly Uni just the be able to read the battery voltage remotely. i hooked it up to a 12v power source to test it and from the diagram I figured I should connect the white wire to the positive and the green wire to the negative but so far I haven’t seen any voltage reading on Shelly app do you mind helping me figure this out please thank you
