Shelly Uni becomes unavailable
I installed a Shelly Uni to trigger a relays that is attached to the door opener. Works fine if I use the shelly app on my phone or the web interface of the Shelly Uni. No network problems or anything like this. I configured the IP address to be fix for this device on the network router. So far so good.
Home assistant also detected the device and I configured it inside the home assistant. But It becomes unavailable as soon as I tap in switch 0 and never comes back online. At the same time I can access the Web Interface of the device without problems. Some how HA does not like it :slight_smile:
Do you have any idea how to solve this problem.
