Shelly uni plus over counting pulses solved
Long story short I was using a switching 12v adapter and was getting a lot, like 100s maybe 1000s, of false pulses a day. I switched to a linear 12v power supply and now get either dead on or with in 10 of other connected pulse meters.
How I got here. I am using a Shelly Uni Plus to read read the water usage in my chicken house, what puts me in a unique position to most I believe is that I have a pulse splitter (not sure of exact term but it takes the pulse from my reed switch on water meter and reproduces it 4 times) and connected to this pulse splitter is a controller’s water meter and a wifi water meter I bought off ebay thas connects to a cloud. Both these meters read with closely, generally with in 10 pulses of each other or less. When I connected my shelly uni plus to this meter it would appear to read correctly with the 2 existing meters but would gain more and more extra pulses as time went on. I thought it was an issue with the reed switch bouncing although I figured the splitter probably debounced it but do not know. I tried things with resistors and capacitors, I ended up running the pulses through an digital in put as described here shelly uni debounce. I am still actually doing that (haven’t had a chance to try with out it wired this way with new power supply) but it was still getting inaccurate pulses unless I made it act as as a push button inversely I believe and then it would be right but 1/2 the correct amount. I had read some where about a noisy power supply causing issues with some other pulse counter and decided to through a linear power supply at it. I did not expect it to work but it did and has been for days. Hope this helps save someone else hours/days of frustration.
I’m now currently searching for how to integrate this into my energy dash board with the same amount of frustration, I know nothing about coding and do everything with the GUI. I believe it may require doing something in the yaml but I don’t even know how to begin to do that. When I figure this out I will try and share this also unless some one sees this and can tell me how to before then (I have asked how in to other posts)
Thanks for the info. Which 12v linear power supply did you get? I am having the same issue and would like to try this out.
Sorry I just saw your post. I think it ended up being my reed switch and not my power supply although I have not attempted to install a non linear power switch again to see if problem comes back. I have found if the reed switch has 3 wires it will over count for my uni plus but if it has 2 or 4 wires they seem to work fine. What is weird is the 3 wire ones work just fine with my regular pulse counters. This one is working for me 4 wire pulse counter and this 2 wire one 2 wire pulse counter has worked for me. Here are the power regulators I am using 12v linear power regulator but again I would try changing out your reed switch if you have that style reed switch as I started getting bad readings with the linear power supply and 3 wire reed switch. My meters are Dwyers but I believe the reed switches are fairly universal, if the ones in the link look like yours I think they will fit.
