NOTE
This post is a Wi-Fi variant of post IKEA Trådfri Hack: Zigbee bistate for Water Level
BILL OF MATERIALS
- 1pc 1 KOhm resistor
- 1pc 10 KOhm resistor
- 1pc Water level sensor XKC-Y25-NPN 5V-12V
- 1pc 12 Volts power supply
- 1pc Shelly Uni
THE BREADBOARD
THE SHELLY UNI & HOME ASSISTANT
After pairing your Shelly Uni to your Wi-Fi, add Shelly integration to Home Assistant (Settings → Devices & Services). Home Assistant should detect your Shelly Uni automatically.
The device shall have a name similar to shellyuni-12345678A9BC channel 1
This device is of type switch
Now you can add a Button Card to your Home Assistant to get something like this:
(icon hydraulic-oil-level
CONSUMPTION
This setup consumes 30 mAh when water is detected.
For lower consumption see the link in the note above.
