Hello, I have Shelly Wave 2PM devices (QNSW-002P16) with firmware 10.30 which I use to control lamps. I configured an auto-off timer but when the light goes out automatically, the status is not updated in HA. I also use a presence sensor and according to the manual every ON signal should reset the countdown timer, which is not the case.
We are aware of the bug, and it has been addressed. The fix will be included in the upcoming firmware release version 12.xx. This version is currently in development, and once testing is complete, we will make it available for release.
Thank you for your patience.
Once the firmware will be released you will be notified by Home Assistant as you are notified for any firmware update.
@RDS_001
Could it be that with the new 12.4 firmware the state is no longer changed when using the physical switch although the Switch type is set to “Toggle switch (Change on toggle)”?
I don’t have the issue on my 1pm mini with the same settings.
EDIT
Apparently there was an issue with the interview. After re-interviewing the device everything is working properly again.
Just FYI: they have withdrawn version 12.4 from their support site because it contains a buggy SDK. They released v13.0 in a forum but not yet officially on github/support site.
Here’s the link but you need an account on the shelly support forum to be able to download it.
I personally installed it on 1 device but prefer an official release before installing it on all devices. PS: it did not solve my initial problem for which I started this thread.
