Bigk
(Kenneth)
September 8, 2022, 7:46pm
1
Hi, On all my Shelly units the unit of measurement is wrong it shows kWh and the unit should be showing in W, when I change it in core.entity_registry it changes bach when i have restarted the Home Assistant, what can I do to make it right?
"area_id": null,
"capabilities": {
"state_class": "total_increasing"
"config_entry_id": "a9feda304ebcca69d3992aa8c89a88e8",
"device_class": null,
"device_id": "bf4c9ea51ff5f94162c3509503ed900d",
"disabled_by": null,
"entity_category": null,
"entity_id": "sensor.it_energy",
"hidden_by": null,
"icon": null,
"id": "edc80d9d8e1d8e64db0d006fcc0514c4",
"has_entity_name": false,
"name": null,
"options": {},
"original_device_class": "energy",
"original_icon": null,
"original_name": "IT Energy",
"platform": "shelly",
"supported_features": 0,
"unique_id": "7C87CE658AD4-switch:0-energy",
"unit_of_measurement": "kWh"
tom_l
September 8, 2022, 10:44pm
2
The config you posted is for an energy sensor. Energy is measured in Wh or kWh.
Power is measured in W or kW.
Bigk
(Kenneth)
September 9, 2022, 8:02am
3
Thanks.
Can I change the discovery configuration mode for the Shelly so that it appears correctly.
tom_l
4
It is already correct if it is an energy sensor.
Bigk
(Kenneth)
September 9, 2022, 8:30am
5
It should only show Watt in sted of kWh
tom_l
September 9, 2022, 10:15am
6
That is not the same entity that you posted the config for in your first post. The entity you posted the config for has the name:
The one in your graph is called IT Power
And it has a lot more wrong with it than the unit if it is a power sensor instead of an energy sensor. e.g.
How are you adding these sensors?
Bigk
(Kenneth)
September 9, 2022, 11:45am
7
Sorry, I have two sensors and it is Shelly switch and it is autodiscovery I down´t put them in manuel.
It looks like that it has W as it should, but it shows kWh as you can see.
"area_id": null,
"capabilities": {
"state_class": "measurement"
"entity_id": "sensor.it_power",
"hidden_by": null,
"icon": null,
"id": "215832915d4920ffbe8638f92450f369",
"name": null,
"options": {},
"original_device_class": "power",
"original_name": "IT Power",
"unique_id": "7C87CE658AD4-switch:0-power",
"unit_of_measurement": "W"
