Hi all.
Ive got a shelly1 up and running, as i wanted to evaluate them to potentially replace sonoff T1 touch switches. While the sonoff functionality is good, i like being able to use a normal light switch.
I have the shelly working, but with 1 potential issue. I dont know if this is by design, or if i potentially wired something up wrong.
If the light is off, turning off the switch will engage the shelly. If its then turned off via the shelly, toggling the switch does not turn the light on. It has to be toggled off and then toggled back on again. Something doesnt feel quite right.
